Discuss Best way to lift plywood with Adhesive on top in the British & UK Tiling Forum area at TilersForums.com.
pendleh
Hi there
I would like to know what is the best way to tackle taking up plywood with adhesive on top. I was thinking remove the adhesive with a hammer drill with chisel then angle grinding the screw heads then prying the plywood. I dont really want any splinter damage on the floorboards. Advice appreciated!! Merry Xmas
Best Wishes
Howard:ninja:
DHTiling
To get that ply up without damaging the floor slightly will be tedious...
Firstly, try to locate where the screws are....then use a 15mm hole cutter for timber....use this to drill a hole around each screw...( i did say it was tedious) then lift the ply up leaving behind all the screws and the small round piece of ply....then use a hacksaw blade to cut off every screw...If you have a grinder that could do it or a fein or bosh p180.....anything that will cut the screws off....that is the gentle way of doing it....
Other wise as mentioned straight in with a pry bar....
pendleh
Mabe, and it is just a maybe, if the screws have been put in uniformly you could locate a start point, take off the addy around the head and maybe again, manage to unscrew the screws. It does sound like a lot of work to protect the boards but hey, you know what your wanting to do.
Hope you get sorted out :)
Cheers for that how much damage can you do to floorboards when ripping up ply? screws were not sufficiently long enough to pierce floorbords.What would you use to take the addy off the screw heads?
Best Wishes
Howard
pendleh
Dave thanks for this post!!:santa_cheesy:
Alberta Stone
What are the floorboards that you are so concerned about damaging them???
Are you retiling?
If so it doesn't matter if you splinter the boards a bit.
Often the screws pull through the ply when pulling with a wrecking bar and then you can just unscrew them or use a crowbar to finish it.
If you are retiling then use a polyurethane subfloor adhesive to bond the new subfloor and put a bit extra where there are damaged areas. It expands as it cures and so fills in any little craters and gaps quite nicely.
pendleh
Are you retiling?
Hi Can I ask you more experienced tilers where to get the best information on how to tackle a job - who you should contact thinking specifications etc What is the M40 specification and who oversees it. Any info you could send me appreciated! How do I make sure I use the correct materials and how it should be tiled. Thanks
Merry Xmas
Howard:8:
Alberta Stone
TCNA - TCA Publications
The 2008 version of the TCA Handbook for Ceramic Tile Installation (English and Spanish versions) provides specification writers, architects, contractors and installers industry-consensus, detailed drawings and installation specification guidelines for 101 installation methods. The specification guidelines for each method include recommended uses, limitations, requirements, materials, preparation by other trades, movement joints and installation specifications. It references American National Standards (ANSI) and American Society for Testing and Materials (ASTM) test methods.
* This was the the US version, now they represent NA.
Terrazzo, Tile & Marble Association of Canada
[FONT=Arial, Helvetica, sans-serif]The TTMAC was founded in 1944. Its mandate was to develop a method of standardizing terrazzo, tile and marble installation techniques, as well as being a technical resource and liaison for architects, specifiers, designers and engineers. TTMAC honours this commitment today as well as many other services and support of the hardsurface industry and its members.
[/FONT]
[FONT=Arial, Helvetica, sans-serif]Tile Installation Manuals[/FONT]
[FONT=Arial, Helvetica, sans-serif]Specification Manuals 09 30 00 &
09 66 00 and Dimensional Stone Guide
[/FONT][FONT=Arial, Helvetica, sans-serif]now available.[/FONT]​
[FONT=Arial, Helvetica, sans-serif]The TTMAC develops and publishes the standards for the tile and stone industry. The latest edition of these standards is the 2007 Specification Guide 09 30 00 Tile Installation Manual. [/FONT][FONT=Arial, Helvetica, sans-serif]The guide outlines how, for example, showers, decks, stairs and kitchen floors are to be tiled to insure that installation will be crack free, waterproof, properly laid out and installed with the quality of work meeting standard trade practice.
*This is the Canadian resource.
These are the best resources NA has to offer, I am not sure as to what is over in the UK.
These will most certainly help though, I have hardcopy of both at home and refer to them when I need to.
This will help.
[/FONT]
pendleh
Hi Guys
Thanks for all your help its a great help. Listen I would like to work on some guides like how to self level things like Oli has done which will help my learning. What I need though is a pointer to some good info and your experiences. Like to give something back. If I damage the floorboards this women will want new ones shes very picky:ninja:
Merry Xmas
Happy New Year
Howard
Reply to Best way to lift plywood with Adhesive on top in the British & UK Tiling Forum area at TilersForums.com
Further to my other post re our hollow tiles issue It looks like our tiler has dot and dabbed...
Hi everyone. I have a 1940's semi and i have been redecorating my front room, no its my own...
Hello! I’m hoping I can get some advice on what to do in my kitchen RE wanting to replace the...
Hello everyone, I tried to avoid asking this question as I'm sure you're all sick of seeing...
5K
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
