Discuss Best way to raise existing screed height/depth in the Canada Tile Advice area at TilersForums.com.
Not generally as most flowscreed should need minimum 25mm to be laid bonded. You might e able to use a levelling compound but that would be pricey. As dave says your best option assuming the screed is not heated would be to use 20mm insulation boards....Hi All. Please help. We are 20mm short after putting down the screed before laying limestone tiles (20mm + adhesive). How can we add another 20 mm on top of screed. Can we use 20mm flow screed? Thanks
Which SLC product would you recommend. Its just been mentioned that i may need 30mm over an are of 77sq mtrs. Vbrg
Reply to Best way to raise existing screed height/depth in the Canada Tile Advice area at TilersForums.com
