Discuss Big bit of ply, or cut into smaller bits? in the DIY Tiling Forum area at TilersForums.com.
Bladd
UK
Hi
I am redoing our bathroom. I'm going to be laying 18mm plywood on the joists (16in centres, with noggins) and tiling on that using a decoupling membrane (Ditra 25). My plywood is 2440x 1220mm.
Is it better to lay the plywood in one big sheet or cut it into smaller sheets with 3mm gap between them?
I'm thinking about potential expansion issues. The 3mm gap between smaller sheets will act as a break for expansion.
Reply to Big bit of ply, or cut into smaller bits? in the DIY Tiling Forum area at TilersForums.com
