I've had the odd porcelain cutting probs too, I also have a sigma and made all sorts of adjustments to the gantry, sometimes it works if you turn the tile 180 deg after the initial scoring and scribe the top end 30-40mm then come back down and break the tile about 25-30mm from the other end near the measuring bar and instead of pressing down on it to break it, put a slight pressure on then crack the handle one firmly with the palm of your hand quickly so that the whole tile hardly flexes, this usually does the trick for me :smilewinkgrin:
