Discuss bit help in the UK Tiling Forum area at TilersForums.com.
you can brush it on. depends on how much stone you have to seal. paint roler is just as good. sorry should have said to clean at each stage. thought that was common sense. I put all stone through wet cutter and mark with pencil. Most pens just get absorbed into stone. Most times i use a white adhesive.
Reply to bit help in the UK Tiling Forum area at TilersForums.com
