Bnc cable with power messed up for cctv Discussion ThreadBnc cable with power messed up for cctv Electrical Advice
Hi I have stupidly cut the cable to push through the wall . Idea was to join them back together.
There's 2 wires inside blue and a white one. The white one has copper strands exterior around it.
When I joined it back together. The camera didn't work.
I'm unsure if it's down the cable I've knackered now from that bit. Or I might have nicked it from outside when trying to put on the cable clips when clipping against exterior wall.
So I guess what I'm asking is. Theoretically can I fix this cable from where I cut it. If so then I need to examine the wire from outside but I require ladders to do so.
You can see from the pics there is the 32 stranded copper that I need to attach. Which did before. That's very flakey some strands fall off
Bnc cable with power messed up for cctv for the original thread on Electricians Forums
