Boiler side connections for UFH wiring centre
I've been away from electrical work for about 30 years so I'm not familiar with all the names and terminology that's been introduced over the years.
We're having UFH heating installed. Plumber is doing the pipework, s-plan etc and I'm installing a Heatmiser wiring centre. for the electrical side. Wiring everything up as per the attached diagram is pretty straightforward but I'm looking for confirmation where the boiler side connections go and looking for some help from those with experience. It's an oil boiler by the way and it's all the different terminology for volt free, dry contacts, etc that's confusing. COM/NO for some boilers, Ls, Lr or L, S/L etc
I asked the boiler manufacturer for advice, but because it was a 3rd part wiring centre, they didn't want to give advice and told me to consult the installation manual and work it out from there instead.
So, the heatmiser is a volt free connection that goes to the "boiler enable" terminal but there is nothing labelled as boiler enable. From the boiler manual (images attached), there is a COMN4 terminal with a jumper to be removed. I presume that Ls form the heatmiser wires into L(5) on the boiler and Lr wires into S/L (4) on the boiler.
For the dip switches, I need to set the demand mode to "switched live" and dip switches 6 = OFF, 7 = OFF, 8 to OFF
From what I can gather, "volt free" isn't an actual supply, but is a relay voltage between 0-230v that is a switch that tells the boiler to start heating.
Have I got this right or not? Just want to be sure so that I don't send a voltage that fries the main circuit board.
Continue reading...
Electrical Advice
Tags Tags
centre ufh
RuraidhBoy,
RuraidhBoy,
