Guest viewing is limited
Discuss Bosch GTR 30 - Gimmick tool or worth having? in the UK Tiling Forum area at TilersForums.com.
Hi guys
Thought I'd ask your opinions. I keep seeing these advertised and they look quite useful but I'm just not sure how good they are and if I would get my money's worth out of it.
Has anyone got one and would you recommend them? I do a lot of stone work so the scribing side of it looks worth having but what's it like at cutting holes with the core's? Has anyone used it on 20mm granite/marble/limestone?
Thanks in advance
Its mainly stone tiles I fit. The occasional porc job. Thought I'd upgrade my kit and get some pukka hole cutters. What do you guys use for cutting holes on stone and porc? Is it better to go with the 365 kit and keep replacing them or go marcrist/rubi kits? The new marcrist dry hole cutters to go on grinders look like they would be tasty on stone. Anyone tried them?
K
KL Tiling
I use Armeg hole cutters for porcelain. They're not cheap but they do give a nice finish. I bought this kit Armeg Porcelain Tile Cutter Piping Set 8Pcs | Screwfix.com but there are lots around and probably cheaper but this one does the job nicely. I also do a lot of stone and I haven't found anything that beats Disston Remgrit Holesaws which you can get from Screwfix. They are relatively inexpensive and do a fantastic (and fast) job on most types of natural stone. Here is a link to the 35mm Grit Edged Holesaw 35mm | Screwfix.com but they come in a variety of sizes. I'd recommend drilling a pilot hole first with a standard glass/tile bit (the Armeg ones last for ages).
Reply to Bosch GTR 30 - Gimmick tool or worth having? in the UK Tiling Forum area at TilersForums.com
23K
Deleted member 57709
I would very much appreciate the advice of anyone who has fitted Marmox boards as I have decided...
6K
Hello everybodies! I've decided to sell my wet cutter. Rubi's beast of a machine, The DX 350...
6K
Italy
I
Recently I stocked up on a selection of the core drills and in the past I havet had issue. The...
stone tiler
Surrey and South East
Website
http://www.thetileemporium.com
Business Name
The Stone Tle Emporium
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
