Currently reading:
Brick Bond (Metro) advice
Discuss Brick Bond (Metro) advice in the DIY Tiling Forum area at TilersForums.com.
Z
Zub
Hi all,
First time tiler. Decided to tile the kitchen after a fire destroyed the old one.
I need a bit of advice as to which layout I should use for the pipe which has been boxed in.
Do I ignore the bond on the arch, split each side of the boxing into half and brick bond? Or do I continue the bond from the archway? If so, how? I've attached a few sketches below. Sketch 3 looks the most appropriate to me, however that would go against what I have on right corner.
Help!
Thanks in advance
Z
Zub
Since you guys have been so helpful, can I pick your brains with a few finishing queries which are specific to bevelled tiles?
1) How do I finish off this socket? Cream coloured silicone? (as grout may crack after time to movement in the socket when changing plugs)
2) How would I get a clean silicone line where the tile meets the unit? I'm guessing fugi-tool wouldn't cater for the bevel.
3) What does 'scribing a corner' mean? One tile flush against wall, second tile mitred at 45degree and then profile cut off and butted in? As you can see from the pic, i've messed up one corner but would like to avoid this error on the remaining corner
4) On the 'boxing in', I've decided to use a tile trim as I am nowhere near competent enough to mitre. How would I deal with the bevel (diamond) against the trim? Grout and forget about it?
Andy Allen
1,318
Gloucester
1....colour match silicone round the socket.
2...i just use my finger...... But a tool will be fine.
3...scribing metros means to cut the metro shape out of one side of the cut tiles. I would just cut them as normal and colour match a silicone joint in the corner with the same colour as the grout.
4.... Just grout it and forget about it...
Z
Zub
The Fugi tool would work down the side of the socket. I would just mask up the side of the socket as close to the edge as you can get, run the bead of silicone into the joint and then using the 90 degree square edge run that down the tile and remove tape.
Thanks - What about where the tile meets the units though? and the internal corners? As others have said, I think using the same colour grout and silicone (mapei grey), with a few attempts i think can get it blend in somehow.
John Benton
1,138
Leeds
For me I would use the white on internal corners and against the units. Reason being, because of the bevelled edge on the tile the thickness of the bead will change each time it changes angle. It will really stand out, grey over white, the white would be less noticeable.
Z
Zub
Good point. Thats my biggest concern, getting a constant straight bead over the angles whilst somehow ensuring the 'diamonds' dont stand out. I guess I'll only know when I get round to siliconing.
I'll try both white n grey n see what looks best. Thanks for that.
View attachment 94133 View attachment 94134 View attachment 94133 View attachment 94134 I'm a bit late entering this thread, have just done a kitchen with white metros and grey grout, always use a neat silicone seal on all internal corners, against units and worktops. The Mapei grey should blend in quite well (I just spray with a little water with a drop of washing up liquid added and smooth over with a finger tip, multi wipes really help to keep things neat). Looking really good so far, had to tile a arched widow a few years back and the underside, cut individual pieces of trim to fit.
Z
Zub
Evening - for some reason your attachments aren't showing up.. Might take a bit of time to replicate onto the forum maybe?
Reply to Brick Bond (Metro) advice in the DIY Tiling Forum area at TilersForums.com
