Discuss brick floor in the Australia Tiling Forum area at TilersForums.com.
Hi All
Have a floor to tile in flooring grade brick tiles(50mm thick) Not done these before and only seen a sample.Customer wants them laid like block paving i.e no joints and I presume with some sort of pattern-maybe herringbone.Firstly,is that possible?-no u/f heating either and this is where there could be an issue.Builder is replacing the floor on Monday with a concrete slab and wants it tiled the week after! I said to wait for the drying out period but he said that because the bricks are breathable it should be ok-Does he have a point? I was planning on using an unmodified adhesive too or do you think ditra mat-any thoughts?
Mike
Rich Midge
Morning Mike, not laid these myself either. Bal do a Green Screes Adhesive, Tilemaster Ultimate can go onto green screeds also Norcros Permalayer allows you to fix to new concrete. Personally, without guarantees from the suppliers I'd be waiting for it to dry. Also imo a minimal spacing between tiles is necessary and a good 10mm perimeter expansion.
Reply to brick floor in the Australia Tiling Forum area at TilersForums.com
Hi I asked the Wunda technical department if I can just use a Ditra mat only and not the SLC...
Hi, I'm planning to do a herringbone brick floor over a concrete slab with some reclaimed brick...
I'm a total tiling beginner having my kitchen/diner redone by builders. The dining area has a...
I'm embarking on tiling a kitchen, wall-to-wall (under washing machine etc). most of the floor...
Hello guys. I came upon and registered with this forum while doing some research on decoupling...
5K
oxfordshire
brick floor
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
