Discuss Brick slip advice in the Canada Tile Advice area at TilersForums.com.
Good evening,
i have a project coming up to tile a fireplace interior with real brick slip tile.
The interior has been sand/ cement rendered around 3 weeks ago. The fireplace is decorative only so heat won’t be a factor.
After priming with BAL APD i was thinking of back buttering the brick slips as the grout widths will waste a ton of adhesive, would there be any issues with this?
Thanks in advance for any advice
Joshjupp
558
Maidstone
Cheers Josh, much appreciated. Also as I would normally Silicon into the corners for expansion, would it be ok to grout into the corners or just leave a narrow gap between the side wall and back wall? I hope that makes sense
I’ve never siliconed brick slips before I don’t grout them either I get a bricklayer to point them instead I think it looks better than grout personally
Joshjupp
558
Maidstone
Sorry mate when I said grout I meant pointing. Also I meant what would I do instead of Silicon in the corners, do they need an expansion joint as its 3 walls each around .75 m2. Cheers for your reply mate
As it’s only a feature and not being used as a fireplace I wouldn’t see a need for expansion joints
Reply to Brick slip advice in the Canada Tile Advice area at TilersForums.com
Hi Guys i’m going to be tiling over skimmed plaster walls in a kitchen for first time. (first...
Hi Tilers, this is my first question on this forum and I've got a few different areas to cover...
Hi All, It's my first post here. I'm currently working on a wetroom in my flat and would love to...
Fareham
What member type are you?
  1. Homeowner
Business Name
My house
Brick slip advice
    Votes: 9 6.0%
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.3%
    Votes: 17 11.3%
    Votes: 36 24.0%
    Votes: 2 1.3%
    Votes: 21 14.0%
    Votes: 18 12.0%
    Votes: 16 10.7%
    Votes: 7 4.7%
