Discuss Brick Slips fixing advice in the DIY Tiling Forum area at TilersForums.com.
gaggarwal1981
Hi, I would welcome some advice as I have got myself into a pickle.
I planned to attach brick slips to a bonded coat in my kitchen however have realised that they will be too heavy to be directly attached so am now considering attaching a cement based back board but am not sure how to fix it. I can not use baton as I no longer have the space.
My current wall is built as follows; Solid wall with 5cm Kingspan insulated plaster board attached with dot and dab. This has then had a coat of bonding applied.
Can I glue the board to the bonding coat??
If it needs to be mechanically fitted, what would I use and would screwing to the plasterboard be enough or should I fix to the brick.
If I apply brick slips to the bonding direct, a few levels at a time, would the plaster hold??
Thanks.
Aaron
Dan
Admin
Staff member
5,093
1,323
Staffordshire, UK
I think you'll need to mechanically fix to the substrate but this is out of my league I'll leave it to the pro's to advise.
I'm guessing, and it is just a guess, plugs and screws (using the correct screws that won't tarnish with time) at 200mm centres and use adhesive blobs in the same place on the back of the boards so the screws go through them.
But as said. Not actually sure personally.
Why would u bond over plaster board that will reduce the weight it can hold bonding over it means who ever dot and dabbed it obviously didn't use a straight edge to ensure it was flat and if u was to go over with backer board then brick slips would it hold the test of time somehow I doubt it I would just take all down screw 2b2 to wall dpc behind timber then screw 12 MM backer to to timber job done nice solid base
Reply to Brick Slips fixing advice in the DIY Tiling Forum area at TilersForums.com
Hi all, I'm looking to tile the entirety of our small patio area with either brick slips or...
Hi Guys i’m going to be tiling over skimmed plaster walls in a kitchen for first time. (first...
DIY Tiling Advice Forum
Trending DIY Tiling Forum Threads
Wetroom and Tanking Systems Popular
DIY Tiling Forum
    Votes: 9 6.3%
    Votes: 13 9.0%
    Votes: 9 6.3%
    Votes: 44 30.6%
    Votes: 17 11.8%
    Votes: 34 23.6%
    Votes: 3 2.1%
    Votes: 20 13.9%
    Votes: 18 12.5%
    Votes: 15 10.4%
    Votes: 7 4.9%
    Votes: 3 2.1%
    Votes: 4 2.8%
