Can A Skimmed Plaster Board Wall Support This Tile?
gooty
finally found a tile i like but its porcelein.
it weighs 17kg per m2
will a skimmed plasterboard wall support this with adhesive?
thanks
thanks
British standards states 20kg per metre onto plaster including adhesive & grout so your just good to go.......
adhesive and grout typically weigh 4kg per m2 so that would push total weight up to about 21kg per m2..but yes, I'd probably go for it too.
One builder I work for really gets disgruntled with me regarding issues like this.......the last bathroom was plastered & tile weight was over the limit so I got him to overboard with Marmox glued & screwed, when I told him he looked like he wanted to clip me round the ear!.....oh well he keeps using me so happy days :smile:
most of the time when im tiling the tiles are from a bath or shower tray or floor the walls are usually vertical so the pressure of the weight is vertical and the weight is supported on something . I must admit that the majority of my jobs are not onto skimmed walls which we are talking about.
if your concerned about weight you could put a row of L brackets above your tiles mechanically fix them to your walls and hang your tiles on them weight problem solved lol🙂 have used them in the past to support tiles above windows
used to use L brackets when I did slabbing in the past. have a idea any one know a dragon to lend me some money
ok this is were you have to question the honesty of the tile manafactors who surplie the uk its just to easy to put on the box of tiles coming to the uk but they would sell less and cant blame you for fixing them .think about it
There is a lot of talk of weight limits on here for sure, and I'm sure it is British standards but I think it is a bit Ott. Perhaps if you were fixing to a skimmed ceiling but as said before, on a wall, the weight isn't really pulling on the plaster as such. Have you ever stuck a big tile on to a plastered wall and tried to pull it off, it's not about to fall off
what I would like to know who are these quangoes and have they ever stuck a tile on to any plaster or even know what it looks like
was a bit of time that I wanted to tell you.
(But could not find the words) 🙂
gooty,
Italy,
gooty,
Italy,
