Buzz365
Thanks for the offer, sounds interesting, but on this occasion I will pass. Only up for bownie points so not sure it deserves the trouble... but thanks anyway. I have moved the centre line over 1/4 tile and it doesn't look to bad and it made it work better in the corners.Spot on @JulianSidney!
Sick to back teeth of half bond yaaaaaaaawn!
Random is good!
As far as closers are concerned, before I go into the complications of it, take one tile and cut 10mm from the short edge.
Effectively making them 390mm long.
Then file it sand it, whatever u need to do to make your cut edge look like a factory finish.
If you can be bothered to do that, I will go into the long winded method of closers! That fair enough?
