Martinf
Hiya
I've been asked to tile onto 12 mm sterling board which has been used to create a new wall. The board is pretty solid (no movement), but I'm finding that the tiles won't stay up, even though the board has been sealed with 3 coats of PVA.
I've since been advised by a tile supplier that sterlingboard can't be tiled on because of the resin used to make the board.
Has anyone come across this problem before or do you know of a good primer/sealant that would allow me tile onto the existing sterling board (the only other option I can think of is to get the walled lined with ply on top of the sterling board and then tile on top of that.)
Martin
Martin
