Discuss Can you help with tiling above bath in the DIY Tiling Forum area at TilersForums.com.
Brob90
Hi all
I am currently looking to tile bath to ceiling in my house as I'm installing a shower above the bath. I've tiled floors but this would be my first wall.
Current setup.. sheet of plywood behind 12.5mm moisture resistant plasterboard. It is screwed into the ply all over the shop and has the thinnest skim possible (built in the last 3 years).
The issue is my other half has selected some really nice tiles.. 600x150 10.5mm porcelain, so they weigh roughly 23-24kg/m2 then plus the 4kg/m2 for adhesive and it ends up a bit over the weight limit for skimmed plasterboard.
I am trying to run this on a bit of a budget at the moment, but wanted to get your advise on what you think would be best to do in this situation.
Thank you in advance
That will work just fine, I'd advise Ardex WPC as a tanking kit, it's ideally suited to a diy project and fairly difficult to get wrong if you follow the instructions.
Just wear long sleeves if you apply with a roller. :)
(Unless you already shave your arms!haha)
A standard set S1 adhesive and anti bacterial grout.
Brob90
Thats awesome. I'll check the ardex tanking kit out! Thanks for the recommendation!
Good to know I was thinking on the right track! Now just to fit it all in the car haha
Reply to Can you help with tiling above bath in the DIY Tiling Forum area at TilersForums.com
Hi all, I am in the middle of renovating my bathroom. First of its kind for me! The walls were...
I’m halfway through tiling a shower cubicle at home. First time doing any tiling. I’ve used...
Hi there, long time lurker, first time poster. I’ve recently moved in to a new build property...
DIY Tiling Advice Forum
Trending DIY Tiling Forum Threads
Wetroom and Tanking Systems Popular
DIY Tiling Forum
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.3%
    Votes: 17 11.3%
    Votes: 36 24.0%
    Votes: 21 14.0%
    Votes: 18 12.0%
    Votes: 16 10.7%
