I don’t even know what that means Jim.Look here,get urself a ps4 and download fortnite.
I don’t do video games.
Discuss Can you resin fill ceramic mitres in the Australia Tiling Forum area at TilersForums.com.
yavolWant to learn how to do this lol
Love this...
Vanity frame was made out of wood and ply. I took measurements for limestone, allowing for mitres. Stuck 1 inch masking tape to edge where mitres are (on face of panel ). First fitted top piece using clear Silicon, then all other pieces on Silicon , but at the same time with plenty of cream stone glue on mitred part. (Have to push two panels really tide ,so excess stone glue will come out and masking tape will protect face of stone ). When all pieces glued together, just use polisher starting with pads 120, then 220 and 400( depend on stone finish. For high polished marble, you would need to go up to 1000 ) . And when all polishing is done , seal stone with stain stop.Love this...
Can you run through the process please?
Just noticed, you didn't continue brick pattern on window return, is there any reason?. Also looks like there are two windows in your photos , and they are slightly different level? one is lower then other?Turned out ok for a first timer lol you were right the biscuit started to show so had to sand lightly
View attachment 99830 View attachment 99831 View attachment 99832
Brick bond , give you that but horses for courses. But as to window heights look where the first bed joint runs against the plastic window frame . The only way he could of made those the same height is by refitting the window .Just noticed, you didn't continue brick pattern on window return, is there any reason?. Also looks like there are two windows in your photos , and they are slightly different level? one is lower then other?
Okay, then second window could have been done full tile against the plastic window frame. Obviously that is window fitters fault ), didn't have laser level....Tiler did lovely jobBrick bond , give you that but horses for courses. But as to window heights look where the first bed joint runs against the plastic window frame . The only way he could of made those the same height is by refitting the window .
Reply to Can you resin fill ceramic mitres in the Australia Tiling Forum area at TilersForums.com
