simbob
Help! Is there some magic art to Silicon sealing? I've re-sealed the same area behind a sink twice now and still the water gets through. Sink is set in a standard laminate top, but the wall panel is veneered MDF (hence the need for a good seal) coated with polyurethane varnish, but it's the laminate on the horizontal surface that is the problem.
Initial prep consisted of much wiping down of the area with propanol alcohol (decorators wipes). It was left 24 hours before being subject to water, 1st time i did quite a small bead, second time i doubled the thickness. I can only think maybe it's the Silicon i used, which was just an own brand one - is there really any difference between the branded ones and DIY stores own?
Tips, tricks, advice or magic spells welcomed, thanks.
