SteUK
Hi all,
First post, so please be gentle!
Preping our bathroom to drag it out of the early 90s and make it a nice place to spend time in. Ripped a lot of the old tiles off to find that some moisture had got behind and blown the finish plaster coat. The wall is 50mm breeze block, 10mm bonding plaster, 3mm finish plaster.
Bought some cement boards - no more ply as they do a 6mm and said I could attach straight to the bonding coat with single part flexible adhesive and mechanical (screw and plug) fixing for added safety. I was sceptical so contacted Mapei who have advised I cannot fix straight to the bonding. Bit of a pain in the ***, but not a problem as I can finish a wall that size no problem.
Tiles I will be fixing are 300x200x9mm, and weight approx 16kg/sqm. Decided to cement board out the walls as they are a bit out of level, and the finish plaster in parts is a bit patchy (where two windows were made one and a wall removed to make separate bath and toilet room one room). Also I like the added water barrier the boards add (I will be tanking as well for belt and braces!).
So what is my question? Well, it suddenly occurred to me that I am fixing these cement boards to a finish plaster...that can usually only hold 20kg/sqm. Or is that incorrect as I am mechanically fixing them as well? Or for some other reason?
Advice very welcome and appreciated!
Thanks!
Thanks!
