Guest viewing is limited
Discuss Cement boards on a wall in the Australia Tiling Forum area at TilersForums.com.
mike1979
The question I'm asking is I have a small section about 0.8 m x 0.9 m in a shower the one wall is stud so that will be ok but the other wall is block and I need to boards to be 10mm off the wall as the rest is plasterboard so my question is can you successfully Dot and dab the boards using rapid set then the next day screw them
Reply to Cement boards on a wall in the Australia Tiling Forum area at TilersForums.com
    • Friendly
I'm thinking maybe not? I'm used to cement board so my go to. Maybe I can cement board the...
Hi all, I am in the middle of renovating my bathroom. First of its kind for me! The walls were...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
