Discuss Cement Boards in the Canada Tile Advice area at TilersForums.com.
I am tiling a cloakroom and small lobby which have a new screed floor. I want perfection, and there are slight imperfections in the level so is there any problem with laying down aqua board? If so, does it require fixing?
Floating is a bit tricky because we there is a gap all around the floor where we have put wide foam strip for expantion (standing upwards) so the mix could leak away down the sides.
I am also battening out around a Geberit WC frame. Should I batten over the top of the frame or stop with battening level with the top?
I am thinking I will tile the top?
Reply to Cement Boards in the Canada Tile Advice area at TilersForums.com
Hi all, I am in the middle of renovating my bathroom. First of its kind for me! The walls were...
I am sure someone will know a good practice solution. We started a wetroom last year and then...
Hi All So around 10 years ago (i had no idea it was that long ago until i looked up the order...
Hi everyone, I'm looking for some advice on final floor buildup. We're installing a shower tray...
I need to tile over a concrete floor on ground level (Utility & WC) and a first-floor timber...
Hertfordshire
Cement Boards
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
