Discuss Ceramic floor tile adhesive.. in the UK Tiling Forum area at TilersForums.com.
I will add my two penneth for you:thumbsup:
If this was my job and I had arrived with this 'epoxy paint' already down I would be:
1. Mechanically removing the paint and bitumen residues using a grinding machine suitable to the floor area size with a dust extraction kit.
2. Assuming it is free from deflection, overboarding the chipboard with Hardie Backerboard as per manufacturers instructions.
3. Screeding the conctrete with a suitable SLC up to a flush height with the HBB, leaving a movement joint between the two.
4. I would be taking a look if it was possible to set a full tile away from this movement joint. In that I mean does it leave you with any silly small cuts anywhere.
5. Installing a preformed movement joint at the junction between the two floor constructions with an infill colour to match whatever grout you intend to use or alternatively you could just leave this joint ungrouted and fill with a suitable flexible sealant.
Hope that makes sense to you:thumbsup:
And get a decent adhesive, such as Mapei Keraquick for the whole lot.
Reply to Ceramic floor tile adhesive.. in the UK Tiling Forum area at TilersForums.com
Hi, I have a very small area (1m.sq) on an exterior doorway entrance wall to tile. I would...
TF Group Please Join
