Check me out!
That's a great bit of advice, cheers.
I do the exact same as Bri has done in the photo.
I'm not a multi-trader though. [emoji1][emoji1]
Ive got a festool plunge saw now but that set me back nearly 600 quid with the tracks but worth every penny. The system i described was how i used to do it. My festool is like the sigma or rubi of tile cutters :thumbsup:
To save you the trouble of using clamps and spirit levels and subtracting measurements. There a simple jig you can make.
Get a piece of 6 mm ply of you desired length glue and pin a straight piece of lathe to it. Make sure the width of the ply is greater than your saw for extra stability add draught excluder tape to bottom. Put saw fence against the lathe and cut straight through the ply. Now the next time you cut simply put the ply edge against your cut line with confidence it will cut it bang on. Pictures on request if ya fancy making one :thumbsup:
Are you a chippy by trade david..?
One the best tools in my van !
i hardly ever use my planer anymore really. When im fitting doors this is the beast i use. Back bevel of 3 degrees job done. I ise a makita or freud blade for it works a treat
    Votes: 9 5.2%
    Votes: 17 9.9%
    Votes: 12 7.0%
    Votes: 49 28.5%
    Votes: 21 12.2%
    Votes: 40 23.3%
    Votes: 4 2.3%
    Votes: 5 2.9%
    Votes: 24 14.0%
    Votes: 19 11.0%
    Votes: 17 9.9%
    Votes: 8 4.7%
    Votes: 5 2.9%
