Discuss Chipboard and levelling? in the America Tile Forum / Advice Board area at TilersForums.com.
Hi all,
I have a small WC about 2m2.
I realise now, that I should have taken up the Chipboard floor, levelled the joist and replaced with Ply. However, I went ahead and fitted and levelled the concealed toilet and have burned too much time to rip it all out.
I realised, that the floor was not entirely flat, with about a 10mm drop-off in one corner.
I have 6mm hardie-backer, which I was going to lay down over the ChipBoard and then tile over that.
What's the best option now for levelling before tiling, without removing the chipboard? Is it to Prime the floor, lay the hardiebacker, then self-levelling and tile, or, Prime, self-level, Hardie and then tile?
Or neither of the above.
Many thanks in advance!
HiDIYGuy
Amazing, thank you both for the replies. I shall take your advice.
One thing that slightly puzzles me, is if both the Adhesive used for Hardie and the tile are both water based, is the risk of swelling the chipboard the same? and is the order you suggest. more about getting a good surface for tiling onto?
Dave
Subscribed
389,937
1,000,000
Co.Durham
The water used in the adhesive mix won’t effect the chipboard , it take quite a wetting for it to swell. And yes it creates a better surface to tile too on humidity and expansion issues.
Reply to Chipboard and levelling? in the America Tile Forum / Advice Board area at TilersForums.com
Hi, I'm looking for some advice on the best method to level my ensuite floor. The floor is...
Hi - I'm laying hardiebacker on top of green chipboard. I have a load of Mapei Primer G left...
Hi all, I'm an enthusiastic DIY'er (first time poster) who has been slowly chipping away at an...
So I may have done an oopsie. We are putting self-levelling compound down over floor where I...
I've just had the whole ground floor of a house we are working on levelled with a pump in liquid...
Bishbbashbosh
USA Tile Forum Popular
America Tile Advice Trending
South West
What member type are you?
  1. Homeowner
    Votes: 9 5.5%
    Votes: 17 10.3%
    Votes: 12 7.3%
    Votes: 46 27.9%
    Votes: 21 12.7%
    Votes: 39 23.6%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.3%
    Votes: 19 11.5%
    Votes: 17 10.3%
    Votes: 8 4.8%
    Votes: 2 1.2%
    Votes: 5 3.0%
