chisl bits
  • Thread starter Thread starter pug74
  • Start date Start date
  • Tags Tags
    usa
pug74
being new to the game... i have been reading alot about some of you guys using chisel bits to take up floors with a drill
can anyone explain this more as i have no idea what to do lol (i did say i was new)
cheers
matt
hi mate
use an sds drill with a tile removing chisel, bout 70 quid all in and it will save u using hammer and chisel, you can rip up roughly 5m2 in bout 20 mins, saves the old arms
andy
The "drill" is a demolition hammer, or a rotary hammer with roto-stop.
This is a rotary hammer. This particular one has an SDS-Plus bit shank.
This is a demolition hammer. This particular one has an SDS-Max bit shank.
SDS-Plus bits are smaller than SDS-Max bits. There are other types of shanks, but these two are the most common ones at these machine sizes.
A rotary hammer with roto-stop can be used for drilling, as well as chiseling.
A demolition hammer can only be used for chiseling, but they're generally more powerfull than rotary hammers in the same weight class.
Here's a small collection of SDS-Plus drills and chisels.
Here's a small collection of SDS-Max drills and chisels.
To remove tiles, you need a broad chisel, as they don't "dig" as much as the narrower chisels. There are chisels specific for removing tiles.
To remove tiles, you begin by cracking the grout around one tile. Then you simply hammer away in, under the tile, through the grout line. Really simple actually.
Hi matt..these vids might help you see how it is done....
[yt]EUqwhheYAv4[/yt]
[yt]Tva8-IoMCGA&feature=related[/yt]
And then if you are having a bad day you could take them up like this guy..:lol:
chisl bits
Tags Tags
usa
pug74,
pug74,
pug74,
pug74,
