Hi all. We have a complex circuit in our house which I believe has been wired incorrectly. Despite that, it has been working until I changed two light fittings at the weekend (these are temporary and will be replaced with new lights after decorating). This is how it's configured, with both new and old wiring in place:
Bottom of the stairs - 2 gang 2 way switch, 1 gang for downstairs lighting and 1 gang for upstairs. The upstairs gang has a permanent brown live into COM from another cable. L1 is a black wire, L2 is red, both from the same 2 core.
Top of landing - 1 gang 2 way switch. 1 x 3 core cable. Red to COM, yellow to L1, blue to L2. There was also a light which only had a L+N terminal block with 2 x 2 core cables from the ceiling. I have replaced this with a standard pendant and used Wagos for the L+N connections between the lights and cables. This light is STILL working.
Top of stairs - 1 gang intermediate. 2 x 2 core cables, with red and black from cable 1 into the L1 terminals, and red and black from cable 2 into L2. There was also a light which only had a L+N terminal block with 2 x 2 core cables from the ceiling. I have replaced this with a standard pendant and used Wagos for the L+N connections between the lights and cables. This light is NO longer working.
Bottom of landing - 1 gang intermediate. 2 x 2 core cables, with red and black from cable 1 into the L1 terminals, and red and black from cable 2 into L2. There was also a light which only had a L+N terminal block with 1 x 2 core cable from the ceiling. I have replaced this with a standard pendant and used Wagos for the L+N connections between the lights and cable. This light is NO longer working.
I don't know which cables feed the lights. As we have multiple landings and a stepped roof it is hard to trace them all. My confusion is I have replaced the top of landing light in exactly the same way as the other 2 but they have stopped working. I have replaced the pendants and...
Read more
Continue reading...
Read more
Continue reading...
