Discuss classi-seal in the British & UK Tiling Forum area at TilersForums.com.
gixer
Quick question folks , i have already installed a shower tray using classi - seal only for it to leak a couple of months later :mad2:
Should i reinstall tray with classi-seal taking more care this time to flatten out any small creases in the classi-seal as i feel this is what must have caused it to leak in thew first place , or should i not bother with the classi seal
Thanks in advance Gixer
gixer
Thanks for the tip hillhead with the Silicon , when you look at the black tar like strip of the classi seal it isnt completly smooth , its as if the machine that produced it layed it on thicker in places . When you look at the backing paper it appears rippled , i presume when i first applied it i didnt press this home enough to eradicate the uneveness or press out any small air bubbles in it therefore giving water somewhere to get through .
I did have a bead of Silicon along the bottom where the tile meets the shower tray
Thanks Gixer
Gazebo
Personally i'm not a great fan of classi seal or similar products, i find best way to install tray is to Silicon to edges to the walls when 1st installed, then tank/tile etc. then final bead of Silicon. you can tank walls 1st then Silicon tray in then tile and then finish bead of Silicon...
good luck but I would ditch the classi seal if it is rippled..
gixer
Many thanks folks for the informative replies , unfortunately i have refitted the classi seal , taking more care this time to get a better seal to the shower tray with the classi seal , and applied silcone front and back . Fingers crossed this time no leaks . When reinstalling shower posts to wall am i right in thinking i should apply Silicon at least to the bottom of these to help eradicate any further problems with leaking ??
thanks again Gixer
Reply to classi-seal in the British & UK Tiling Forum area at TilersForums.com
I had a new porcelain patio installed several months ago, and we have been struggling ever since...
I had my bathroom done in September and my floor tiles have movement in them and the grout is...
classi-seal
Tags
usa
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
