dougmontgomery
Hi,
Had a bit of nightmare at work. I poured some floor level onto a step which was to be tiled with new victorian geometric. I then went to get some lunch, when I came back the level had broken/leaked through the barrier I'd set up, and had run all over remaining victorian geometric floor below the step. It must have been on there at least ten minutes. I sponged it off as quickly as possible with several buckets of water, then wiped it with some white spirit. It looked clean through the water, however, in between each sponging off the customer noticed a very slight cloudy film as it was drying (similar to the residue after grouting that you clean off with kitchen towel). I did keep sponging off with more clean water but not sure it was totally successful.
This all happened late in the day and it was getting dark. I won't know until tomorrow if it has left cloudy residue - I did try to reassure the customer it wouldn't stain, but he looked sceptical and now its put doubt in my mind as well. Is it possible for floor level compound to stain, and if it has, is there anything that could clean it off?
The brand of level was Norcos No Nonsense from Screwfix, if thats any help.
Any advice with this would be very much appreciated.
Doug
Doug
