trevortine
Hi all, been reading through posts about mapei grout going off too quickly and giving a few guys problems. I am a bal lover through and through but over the past few years have been using mapei grout. At first like many, i had the same probs with the grout going off really quick. There is a solution to this and it is simply to follow the manufacturers instructions. One five kg bag to exactly 1 litre of water, dont trust the pre marked buckets, get a measuring jug. Mix the grout, leave for two to three mins and mix again. Apply in areas you are confident you can wash off in time, roughly 4 to 5 m2, when you do this you are emulsifying the grout, strike each joint with sponge to create drop effect but dont constantly rub the joint as this can encourage polymers to surface and cause shade variation. This grout is designed to go off quickly in joint which it does, keep an eye on rest of mix and simply whip it up again to make it workable. I was a sceptic like many but after attending a demonstration of the product, i am now sold on it. Hope this helps!
