Discuss Clicking sound when i walk. Need advice in the British & UK Tiling Forum area at TilersForums.com.
tilelover
I have done a 400sqm porcelain floor.
18mm ply has gone down onto joists with 300mm centres
Plywood primed
Ditra down with Ardex af200
Flexible adhesive ontop of the ditra.
Im getting a clicking sound when we walk over the floor for some reason and i havent a clue what it would be. Its not over the whole floor just every now and then
Has anyone else had this happen? Or what it would be.
Also the tiles are starting to get hairline cracks through them.
JIMBOB187
POssibly the clicking noise is the edge of the ply, imagine a laminate floor layed with no expansion gaps and it rubs on the edge of the wall giving a clicking noise, possibly. As for the cracks definetly movement, is it just the glaze cracking or the whole tile, if the latter then the word bugger springs to mind.
tilelover
They are fine cracks. there have been alot of builders with heavy pallet trollys going over the floor doing there rubbish runs. Could this also be a considering factor?
The ply was already done when we arrived.
I would, what would be the best way to go about how to finding the problem?
1) Contact schulter about the ditra
2) Contact tile manufacture to come and have a look
3) start pulling tiles up and inspecting the ply wood base
grumpygrouter
What was your reasoning for the ditra? it doesn't add strength to the floor.
tilelover
To stop any chance of tiles cracking. I thought putting this down, i would have a much greater chance than putting it down straight onto the ply.
The way i understand it, if the floor was to move underneath the ditra would take the strain of it.
I understand that the floor cant move up and down like a yo yo, but if it was to move a few mm here and there then it would be ok.
tilelover
Not with you on this "i would have a much greater chance than putting it down straight onto the ply". Where did you put the ditra, Unless I've misunderstood somethink
Sorry meant to say "i would have a much greater chance of the tiles not cracking and using the ditra than putting the tile down straight onto the ply".
Reply to Clicking sound when i walk. Need advice in the British & UK Tiling Forum area at TilersForums.com
Hi, DIY home owner here in need of advice. Following a waste pipe leak that's now been fixed...
    Votes: 9 5.8%
    Votes: 15 9.6%
    Votes: 11 7.1%
    Votes: 46 29.5%
    Votes: 19 12.2%
    Votes: 37 23.7%
    Votes: 4 2.6%
    Votes: 21 13.5%
    Votes: 18 11.5%
    Votes: 17 10.9%
    Votes: 7 4.5%
    Votes: 3 1.9%
    Votes: 4 2.6%
