Discuss Concrete floor residue query in the Australia Tiling Forum area at TilersForums.com.
On one
I went to look at a small domestic floor job this morning and have a query over the floor prep.
On lifting the existing cushioned vinyl flooring there is a 0.5mm film of black sticky residue on the concrete floor. Is this likely to be the adhesive that was laid to fix the vinyl. The vinyl is about 5yr old.
What would the likely floor prep be?.......Arditex NA????
Spare Tool
only my 3rd post I know and putting myself out on a limb as no pics but think you've answered your own question there, if its a small domestic, on concrete and defo not a dpm and can be scrapped away with a finger nail, for the time it would take would be worth scraping a way with a floor scraper, sbr then maybe a thin skim of self lever then good to tile...imo :thumbsup:
Mark@Tilemaster
NOT VALID
129
283
Leyland
If its still soft and tacky, it is most likely to be the vinyl adhesive residue. Some of these vinyl adhesives used years ago were/are bitumen based. DPM used as a surface DPM should be Epoxy based and therefore if it was a DPM it would be hard/set.
My advice, remove as much of the adhesive residue as possible. If you manage to remove a good percentage of the residue, prime with a slurry mix primer and then apply adhesive or leveller as required.
If you are not able to remove the residue, level with Arditex NA as suggested above. It is the best leveller that i know of for smoothing over adhesive residue's.
Reply to Concrete floor residue query in the Australia Tiling Forum area at TilersForums.com
Hi All So around 10 years ago (i had no idea it was that long ago until i looked up the order...
Hi all again. I'm trying to prep my concrete floor for porcelain tiles. It's just a small 1.5m...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
