Discuss Concrete slab in the UK Tiling Forum area at TilersForums.com.
Ajax123
1,213
Lincolnshire
Standard domestic flooring grade concrete takes same sort of time as screed to dry out properly i.e. 1mm per day unless it is powerfloated which will "seal" the surface a bit more. Something like Green screed adhesive or a liquid DPM or Ditra might be the answer if you need to tile quickly. Bear in mind though that if you tile too soon there is likley to be efflorescence.
david campbell
I should pay more attention.... that'll be 6" then
david campbell
cany beat beat that
Reply to Concrete slab in the UK Tiling Forum area at TilersForums.com
Hi. I've just used Mapei Ultimate Leveller 1210 to cover a very irregular concrete floor in our...
Hi - I ripped up laminate flooring on a concrete subfloor. It was my first DIY project and...
Help! New DIYer here - I’m preparing my bathroom floor to lay ceramic tile. Removed the vinyl...
Concrete slab
