Confused
  • Thread starter Thread starter Onecut
  • Start date Start date
How are you constructing the platform ? Tanking over plywood isn't ideal you may be better off getting a preformed shower former which has the falls already in it ,with out knowing the full spec if what you intend doing it's hard to give good advice ,
It's on marine ply the tanking has a preformed on the moulding to give the fall it comes with a outlet etc
Yes I have one
Hello again
at last the tiles are going on in the wet-room
I have purchased stone looking tiles to run down the center of the shower and across the room over the bowl is it ok not to put spacers inbetween the center runner as it looks better without
as i have aqua panel on the walls plus its a downstairs room with a concrete floor so if i do get a slight leak i wont get paranoid
I wouldn't have ply in a wet room full stop and you need to have a grout line. Tilemaster settaflex is a good suitable adhesive as is grout 3000 also tilemaster. If it says on the tile box itself 'not suitable for wet rooms' then I wouldn't use them but if it's just a shop assistant in B@Q advising you then I would try to get in touch with manufacturer directly.
Confused
Tanking and Wetrooms
Tags Tags
None
Onecut,
Mike ramsdale,
Onecut,
Mike ramsdale,
