Discuss connect UFH to a socket? in the UK Tiling Forum area at TilersForums.com.
masterbuilders
Hi there. I'm instaling a 3m UHF for a customer, and I've always powered all previous UFH from an RCD breaker (sparky doing the connection fom me). In this job the customer doesn't want the fuss of running a new wire from the consumer unit under the stairs to 1st floor bath, lifting floorboards etc.
Is it possible, and above all is it legal, to power UHF from a socket using possibly a fuse box and fused thermostat? Any ideas welcome as my sparky is on holiday and cannot be contacted.
495
1,118
Somerset
Depends on how big the installation is. Things to consider are:
1. Total wattage of circuit - i.e. if wattage per sq m is 200 - you install 20 sq m in conservatory, thats a 4KW fixed load. What else is on that circuit? Will it overload it? Many ufh installations are in kitchen - you could end up with dishwasher and washing machine on same circuit - both have 3kw water heaters inside them. (yours is 3sq m not a problem on ring circuit).
2. You must wire the installation through a fused spur, fuse appropriate to heating load. (Probably a 3A fuse in your case).
3. Cables must be installed in a safe zone (directly vertical or horizontal to accessory) not within 50mm of gas or water pipe (although they can cross, just not run alongside).
4. Only most recent electrical installations have a properly managed consumer unit with dual RCD breakers - system may require upgrading. You must be fully qualified to sort that out.
5. Installation should include a plan of cable layout in floor (your responsibility) and a notice attached to consumer unit (this installation includes under floor heating....etc).
In all honesty, the customer should be referred to an electrician, unless you got C & G 2381 qualification....
Reply to connect UFH to a socket? in the UK Tiling Forum area at TilersForums.com
The dread strikes when the number of a customer appears on your phone several months after you...
U
Hi, I am having my new bathroom installed and have had UFH fitted under my floor tiles. My...
bugs183
Hi all, My first post on the forum, however i have used it from time to time to gain valuable...
stusgsx
U
I hope somebody can offer us some advice. We had an extension built last spring and have been...
11K
I
Just thought I knock up a thread with step by step pictures of an electric underfloor heating...
40K
dean mckeown
