Discuss Continuing tiling above bath on new-build plasterboard walls.... in the Australia Tiling Forum area at TilersForums.com.
Stef
No1s not willing to learn but the advice I give is my advice (it's not bad advice)
Like u say pva has been used for years,
Try a 6 day course instead of a 3day
Never done a course m8, self taught, but from that response it would seem you are the one needing to go on a training course!!
I reiterate that it is bad advice if you are advising someone to use PVA, check up the thread & you will see why not too...
Stef
Go get a bit of what ever type of board u want cut it in half pva 1 of the boards n do what ever with the other1 n tell me if pva doesn't work put water on it after it has set n test agen
Put water on it & you will see that it will become live again!!!
I'm not here to argue, I'm here to give proper advice to the op & in tiling it's wrong to use PVA.
PVA is suitable for a whole host of building works ie plastering as per m2 there isn't the same weight involved as in tiling.
CJ
1,088
Somerset
There is enough info out and about that explains why you should NOT use PVA, but if people are so stubborn, or think they know best....then let them get on with it.
Here's more info.
See www.Mapei.co.uk for more information.
MANY PEOPLE THINK THAT P.V.A. IS OK AS A PRIMER ON WALLS AND FLOORS SO I THOUGHT THAT I WOULD LET YOU SEE THIS " LINK " AND HOPEFULLY IT WILL ENLIGHTEN SOME NEWCOMERS OR EVEN EXPERIANCED TILERS AS WHY NOT TO PRIME SUBSTRATES WITH P.V.A. INSTEAD OF PRIMERS.
P.S. I always prime with primers and this will show you why!!!!!!!
PVA - Why you shouldn't use it as a tiling primer
I have to give guarantees for my work (many of these projects are commercial such as sports centre showers and changing rooms). For me to be able to give guarantees I need to follow strictly the specification of the adhesive manufacturers.
Ardex, BAL and Nicobond are the three suppliers I use most. Their products are similar in many respects, sometimes one will make products the other don't, and I also find some of there products more useful in different applications. All three of them have one thing in common, they all specify that under no circumstances may PVA be used before using any of their adhesives. If you do all guarantees are void.
OK why then? Well I asked this question to Ardex when I once had problem, I'd tiled a bathroom that had been constructed in 25mm Marine ply. Thinking he was doing the right thing, the builder got his guys to seal the ply with unibond PVA...I wasn't aware of this.
I tiled it and 6 months later every single tile fell off the ply, the adhesive solidly stuck to the tile but came clean a whistle off the ply.
We had Ardex Technical down to the site to compile a report, the basis of which was it's the PVA that causes the problem.
When you treat a surface with PVA it partly soaks in and partly sits on the surface of the substrate much in the same way as wallpaper paste.
If PVA gets wet it becomes slightly live again, it doesn't completely return to it's liquid state but it becomes sticky.
When you spread tile adhesive onto the wall, the water in the adhesive makes the PVA live and stops the adhesive from penetrating the substrate and providing a mechanical grip. Basically your tiles, grout and adhesive are being held to the wall by a thin layer of PVA.
Most tile adhesive works by crystallising when it sets (some are slightly different such as epoxy based ones) but generally they all work the same way. Once the adhesive starts to set crystals from and expand into any imperfections in the substrate surface (at a microscopic level) to create a grip. PVA stops this process by creating a barrier between the substrate and the tile adhesive.
Ok so what's the difference between this and Ardex or BAL primer, well basically the tile manufacturers primers soak right in to the substrate and stop the sponge like "draw "effect but they don't coat the surface in any way, they are an impregnator as opposed to a barrier. They also stop a chemical reaction occurring between the cement based adhesive and a plaster substrate, a known problem know as "Ettringite failure"
I hope this clears up any misunderstandings.
So only use PVA before tiling if the adhesive manufacturer specifies it in the instructions.
If some don't or won't take note.........then so be it.
Stef
Hahaha These self taught tilers
Go on then enlighten us to your expert knowledge & let us know how you started off then?
Another tiler with x amount of years experience & too stuck in their ways.
How many have we seen coming through here????
You my friend are on a long list!! [emoji23][emoji23]
Read above what is stated & you might learn something...
Reply to Continuing tiling above bath on new-build plasterboard walls.... in the Australia Tiling Forum area at TilersForums.com
Hi, We are redoing our main bathroom and looking for a second opinion on tanking. We have bought...
  • Sticky
Hi there, long time lurker, first time poster. I’ve recently moved in to a new build property...
    Votes: 9 6.2%
    Votes: 13 8.9%
    Votes: 11 7.5%
    Votes: 44 30.1%
    Votes: 17 11.6%
    Votes: 34 23.3%
    Votes: 3 2.1%
    Votes: 20 13.7%
    Votes: 18 12.3%
    Votes: 15 10.3%
    Votes: 7 4.8%
    Votes: 3 2.1%
