Discuss Contract / insulation board on the floor in the Canada Tile Advice area at TilersForums.com.
Dumbo
Speaking to jackobord once they tell me their boards are used in some car showrooms .
How you apply the backer will not necessarily make or break the instalation (it can do ) but you also have to make sure your background prep is up to scratch . Ie no deflection in joists and also existing boards fix well to joists .
DavidJ
cement board not concrete board is the term.
Thanks. Duly noted.
Nothing wrong with jackoboard on a timber floor but I think they recommend 10mm as a minimum on timber . It's easier to cut and it's insulating as well it's also much lighter to handle. As for weight bearing it has been successfully used in car showrooms according to their tech department .
Thank you jcr. It would have been used successfully in car show rooms by people who know what they're doing rather than a numpty like me! :) I'd end up worrying about it. The 10mm is a bit off-putting as I'd like to minimize the lip into the room. I think I've managed to talk myself out of it.
Dumbo
Thanks. Duly noted.
If your a numpty it can fail with cement board .
Dumbo
I'm not sure if its correct but, I've always assumed that the cement boards will take more deflection out of a suspended floor than the othersort.
You can seal them up with primer and tape the joints to waterproof if required too.
Cement board isn' waterproof it would have to be waterproofed. I have also repaired wooden floors that had cement board
Reply to Contract / insulation board on the floor in the Canada Tile Advice area at TilersForums.com
1950s ex council house, solid concrete floors, about to have the ground floor tiled - hall...
    Votes: 8 5.9%
    Votes: 13 9.6%
    Votes: 8 5.9%
    Votes: 39 28.7%
    Votes: 16 11.8%
    Votes: 34 25.0%
    Votes: 3 2.2%
    Votes: 2 1.5%
    Votes: 20 14.7%
    Votes: 18 13.2%
    Votes: 15 11.0%
    Votes: 7 5.1%
    Votes: 3 2.2%
    Votes: 4 2.9%
