Discuss Correct Tile Adhesive in the Tile Adhesive / Grout Advice area at TilersForums.com.
Good morning,
I am looking to tile my kitchen floor. The floor is 22mm tounge and groove overboarded with 12mm external ply screwed at 100mm intervals.
I have been doing some research into the best adhesive for the job and the Mapei brand seems to get good reviews (I am also considering BAL). I just wondered if anybody could advise me on which Mapei product to use (the tiles are granite). I have tried asking their customer support but have had no reply.
Also do I need to install a decoupling mat? I understand it is meant to help with lateral movement but can't see why the floor would move.
Any advice would be appreciated,
Thanks for your help,
Alan.
495
1,098
Somerset
I don't believe decoupling membrane is necessary, but the S2 grade flexible adhesive is advisable as a "belt and braces" (avoid de bonding or cracking tiles) option. The ply should have a coat of SBR bonding primer applied to rear face and edges of ply (helps prevent drying too rapidly, and thereby the tile adhesive bonds better to the wood). However the S2 adhesives can be expensive (retail prices from £40 to £90/ 20kg bag - you will probably need between 6 and 8 bags). If you are in a building trade you may benefit from opening a general traders account to get additional discount on prices.
I agree with Andy Allen, ply is not the best surface to tile into, but if you follow the adhesive manufacturers advice, you should not get any problems.
Thanks for the input Andy. I've checked out the adhesive options mentioned by localtiler and the Tilemaster S2 adhesive is coming in a good bit cheaper than the mapei so will go for it.
Unfortunately I didn't prime the back of the ply before fixing it down. Would you recommend I lift it to do this (or do I risk delaminating the board?). I understand what you are saying that the adhesive might dry out too quickly so if it needs to be done I'll do it, at the end of the day I don't want to regret it later down the line.
Thanks again.
Ok thats good to know. I bought the ply from the local builders merchants so can only hope it is of a reasonable quality, it is definitely external grade. The tongue and groove is fixed to the floor joists,I made sure to put extra fixings into any suspect boards before overbearing with ply then when screwing the ply down I used long screws where it crosses the joists so hopefully it is as solid as it can be.
So just to summarise from all the advice so far...
I'll go with the tilemaster ultimate s2 adhesive and apply directly onto the bare ply with no decoupler. I intend to go with a 10mm notched trowel and back butter the tiles. I have also bought the raimondi tile levelling system to give it a try.
Cheers to all who have helped,
Alan.
Rookery
Priming the back and edges of the ply is to prevent moisture ingress, not to prevent the adhesive drying too quickly. In any event, BS calls for a ply overlay to be minimum 15mm thick and of WBP or Marine grade, so your overlay is already under spec and possibly not the best quality. I would take it up, overboard with Hardie glued and screwed and fix tiles with Mapei Keraquick using 3mm spacers, grouting with Mapei UCP. Alternatively I would fix with BAL Rapidset Flex. I've never used Tilemaster but it gets good reviews. I might use an uncoupler too depending on the size of the floor and how stable I felt it to be.
Hi,
Thanks for your advice. I have been thinking about what you say regarding water ingress to the ply, surely if there was moisture present enough to cause an issue with the ply then even if it was primed on the back egde I would still have a problem, after all if the ply is securely fixed to the tounge and groove so if moisture was present would the tounge and groove not react to it and take the ply with it causing shrinkage/expansion anyway?
I have read through the prep guide for the tile master s2 adhesive and they say 12mm ply is fine for overboarding the existing floor?
Like I said previously if I need to replace the ply then I will do it. Appreciate all the advice but there seems to be quite a difference of opinion with how best to proceed.
Thanks,
Alan.
Andy Allen
1,318
Gloucester
Main issue you get when tiling a wooden floor is deflection.......it has to be as solid as you can get it with no bounce.
I've seen many failed floors that have been tiled on ply or chipboard mainly a combination of to much bounce and the adhesive not sticking to the wood for one reason or another.
You could just overboard the ply with 4 or 6mm cement boards if extra hight isn't an issue.....this would be belt and braces approach...
If I had to tile on ply I would use bal single part fast flex and bal wide joint grout with GT1 admix.
And use the adhesive as per instructions and back skim the tile .
Hi Andy,
Thanks for the reply...
I have checked out the BAL adhesive you mentioned, I wasn't ready for the £45 per 12.5kg price tag haha! I know you get what you pay for but :eek:
I can get the tile master ultimate s2 for a good price, have you had any experience with it? If I really need to go with the cement backer boards I think I'll just lift the ply and replace it to keep the height difference between rooms to a minimum.
One thing I didn't mention before was the when I gutted the room for renovation I removed tiles from the same floor. The ply that was down was only thin (3mm I'd say) and just nailed to the tounge and groove, tiles appeared to be porcelain but I don't recall seeing any cracked tiles or grout so hopefully that puts me in a good position.
Cheers,
Alan.
Reply to Correct Tile Adhesive in the Tile Adhesive / Grout Advice area at TilersForums.com
  • Question
Hi, I am planning on tiling my concrete garage floor with porcelain tiles. The concrete was laid down several years ago by a previous owner, and it looks like it was also polished and sealed -...
  • Question
Hi, I‘ve just finished tiling the majority of my garden path. Base is concrete, and tiles are porcelain. I’ve just got to the end of my bag of Mapei flexible rapid set tile adhesive (powdered)...
  • Question
Hi, long time lurker, first time poster. Over the years I've used the good advice that I've read on this forum but with my current project I am a bit stumped. I am renovating an ensuite, it's...
Hi all, I'm hoping you can help with some feedback, please My parents are currently having a new bathroom installed, all stripped back to bare walls and floor. The fitter has done/hasn't done...
  • Question
Hi all, I am planning to tile a full height panel of split face tiles to sit 3” behind a log burner on a plaster render on blockwork wall. I’m planning to score and scrape the paint off the...
