Discuss Cracked porcelain in the Canada Tile Advice area at TilersForums.com.
rj1884
Hello. I've uploaded some photos which I hope you can see of a job I've just been to look at. Cracks like the ones in the photos have appeared in various places in a large entrance hall in this house. The crack doesn't follow one line and some are in and around the door threshold/frames and some Randomly in the middle of the floor. The tiles are porcelain as in photo 4.
the house was built 4/5 years ago and the tiles are fixed to screed which has UFH pipes running through it. I've looked around the perimeter and it seems grout has been used in the expansion gap from floor to wall.
From your experience what would have caused these random cracks as I'm going to be removing the cracked ones and fixing new ones.
thanks in advance
rj1884
Thanks for your replies. I asked about the decoupling mat and no matting was used which I was surprised about. Not exactly sure when the cracks appeared but i'd say they are recent. i would suggest the joints are no bigger then about 3mm.
I'm hoping that there's limited damage to the screed after removing the tiles
Ajax123
1,213
Lincolnshire
Pound to a penny if you lift the tiles the screed will be cracked following the same line. This means the screed has become unsound and should be repaired. Unfortunately it is not as simple as that if the screed has no joints across door thresholds and the like repairing it will probably just lead to the cracks moving and rebreaking. I think your best bet is to repair them as best you can using a flexible epoxy resin to help reduce any vertical movement then replace the tiles with an uncoupling membrane. I don't think this will give you much choice.
AliGage
Subscribed
4,531
1,188
Peterborough, England
What area is there in total? I think i would be approaching the subject of a complete rip out, repair, decoup and fix.
If the cracks have been appearing ever since built there is no guarantee that after repairing the ones evident at the moment that more won't appear.
Reply to Cracked porcelain in the Canada Tile Advice area at TilersForums.com
hello new here but wished i had found and asked before screed and ufh down but here goes. We...
There's a video on youtube of a guy templating for large format floor tiles, and I get the...
Cracked porcelain
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
