stevegreen
Hi, hope someone can help, I have tiled three quarters of my kitchen floor which has wet underfloor heating and sand and cement screed. The room size is approx 8m x 5m and has an expansion joint splitting the screed into two bays. I have been using mapei makeper tiling adhesive. Prior to plastering the room I covered the whole area with cardboard to protect the screed, and have been uncovering as I go. My problem is - when uncovering the last area to be tiled, I have found a crack in the screed which goes across the width of the room (but not in a straight line) the width of the crack at most is only 0.5mm wide.
I can't use an isolating matting in this area as i won't be able to maintain the correct levels. Has anybody got any suggestions about tiling over this area that would help in preventing the crack affecting the new tiles.
Thanks.
Thanks.
