Discuss cracked! in the UK Tiling Forum area at TilersForums.com.
How would I resin stitch crack?
sounds a good way alan but i guess you'd have to be careful if there's ufh pipes in the screed? i know they should be clipped down but i've seen some near or on the surface a few times when they've lifted as the screed is pouredtake a disc cutter and turn the blade on its side so the corner of the blade is in contact with the top of the crack. Run it along the crack to create a "funnel" shape at the top of the crack. vaccuum out any dust or debris that is created. check for vertical movement either side of the crack (stand with one foot either side of the crack and put your weight as heavily on one fot as you can and see if the screed moves. If it does this needs to be stabilised (no uncoupling mat will do this) to stabilise the screed you cut small slots at right angles to the crack running from one side to the other. Repeat for the length of the crack at roughly 1m intervals taking great care to ensure that you do not cut too deeply. You then drop into each slot a peice of stainless steel or plastic bar. If there is no movement then this part can be omitted.
Once you have done this you simply mix up your resin and pour it into the crack. It will settle so allow it to do so then top it up. Scrape any excess off the top of the screed and then leave it to set (24 hours)
If you want to over lay the crack with reinforcing fibreglass mesh then you pour the resin so that it over flows the top of the crack and then place the mesh into the resin.
Sounds complicated but really if you think about it it is really simple. The only issue I see with this is if the screed has cracked because it needs a joint at that point then no repair will help you because it will simply crack somewhere else nearby. However given the age of the screed I would think it has done any movement it needs to do.
Thanks for reply - there is no vertical movement, but how does the resin tie the screed together without ties , or is the resin just to fill the crack?
Where can I get the resin from?
I have in the past used a single tube with a special nozzle which contains a 2 part resin and mixes in the nozzle as it flows out.
Reply to cracked! in the UK Tiling Forum area at TilersForums.com
