cutting a circle in marble
L
ladytiler
hi guys,
can somebody give me some tips on how to cut out a perfect circle out of a marble tile and a porcelain tile for a waste pipe.
we are tiling an ensuite in marble wall tiles 300mm x 300mm and there is a waste pipe that i have to fit a tile over. the pipe is the waste for the toilet. also we have the same scenario in the bathroom but the tiles are porcelain and 600mm x 330mm , i think?
so, how would i cut the hole out of the tiles without splitting the tile in half. :huh2:
hope somebody can help
sara
I use a Montolit cutting set. Fabulous piece of kit but like everything else of quality it costs around £280 for the set. There is also a company on here called 356 Drills I don't know if they have anything that can handle it because I don't know the range.
Kev
Follow the link at the top of the page for Porsadrill and look at their stuff. that will sort you out.
Hi Sara..
You can buy a drill bit from 365 drills that will cope with that size hole.....here's a couple of pics....
Or you can mark the holes size and then plunge cut from the back of the tile and make a few cuts and nibble the shape out.....but for about £60 i would go for the 365 hole cutter then you can use it again....
you can order one here.....
Got to agree with previous posts, 365 Drills supply a 120mm core drill for this very purpose, I cut 2 smaller holes (40mm) in granite last week in about 5 mins total. Will go through marble no problem.
Grumpy
are there any other alternatives. ie one where i dont have to spend money hee
we have a small diamond cutter so i was thinking of cutting out a triangle after marking a circle and then cutting lots of small segments on the strips that are left but will nippers snap off small segments of marble and porcelain.
i thought there would be some old expert out there who would give me some of his wisdom and expertise.
ta
sara x
As i mentioned Sara.. you can do plunge cuts on your wet cutter and cut the hole out in small bits at a time or maybe even use a grinder and finish off with some nibblers.....
ta
sara x
After 10 or 15 mins of nipping away at porcelain, you may wish you had bought the drill.:grin:
Grumpy
sorry dave i didnt read your post thoroughly, typical women hey. i would love spend £60 but my husband would kill me ha. he claims i spend enough.
thankyou
No probs...:lol: ..............women spending money...they don't do that do they....:grin:
................let us know how you get around it then and maybe a pic or 2 eh.!!!!
Mark your tile with the circle then plunge cut on your wet cutter, moving tile up and down plunge cutting it in different areas but not going past the marked area. Then when large chunks of tile have fallen out nibble at the remaining bits with either parrott nips or larger nips up to the marked circled line.
Mark the circle to be cut onto the tile, be it marble or porcelain, Now get the angle grinder out and put a continuous rim diamond wheel on it. Once you've done that fire it up and your first cut will be to have the grinder laying with the wheel facindg down paralell with the tile surface the gently start to scribe the circle using the flat part of the wheel doing this will reduce chipping then once you've scored all the way around the circle plunge cut the bulk of the center out of the hole to be cut it should form an octogon or there abouts then instead of using the nips position the grinder under the tile and start removing the small sections that are left gradually till you meet the scoring you've done previously.Keep your strokes gentle and smooth a steady hand will help alot.
Hope this makes some sense. Good luck:thumbsup:
thanks for all the suggestions guys.
just one last point. on the pic that shows the hole that the 365 drills cut, what is the largest grout line you can have around the waste pipe. it seems quite large on the pic. i was told that wall grout lines should be around 2mm on large formats.
sara
That sara was for just illustration purposes...you can buy the hole cutters in a size to fit your pipe size...or if you are using one of the other methods then leave a couple of mm all the way around then just Silicon this joint so it doesn't crack....
now i know why you are a super moderator, thank you once again dave your advice is appreciated
sarah
x
i agree its not worth you buying a bit go to where you got the tiles and find oot where they get there inset tiles cut iuse a company called matrex lasers it should cost about £20 pound failing that marcrost blows the competition oot the water (quote which mag )
this thread is nearly 2 years old now....:lol:
............. and breathe :lol:
ladytiler,
paulyoung666,
ladytiler,
paulyoung666,
