Discuss Cutting Aluminium Tile Trim in the British & UK Tiling Forum area at TilersForums.com.
rob
Many thanks for your reply
Yep, if you are only doing a couple of mitres - then a small mitre box is the best tool to use. For best results use a normal hacksaw with 32psi blade (very fine teeth). Just remeber that for best results you need to change your hacksaw blade regular. I only make about 10-20 cuts per blade before changing (or change each job). Just keep fingers clear, as metal trim tends to slide in the mitre box. Hope this helps :grin:
redjules
Thanks for that Rob I actually went out at the weekend and bought a couple of 32tpi blades and a wooden mitre box. Think when I cut it I'll use some masking tape and some sort of clamping arrangement to stop it sliding around. Just for reference for anyone else I can tell you that neither Wickes or B&Q/Depot don't sell these blades (only 18 or 24tpi) but Screwfix Trade Counter in Watford had them in stock.
Reply to Cutting Aluminium Tile Trim in the British & UK Tiling Forum area at TilersForums.com
There's a video on youtube of a guy templating for large format floor tiles, and I get the...
    Votes: 9 5.8%
    Votes: 15 9.6%
    Votes: 11 7.1%
    Votes: 46 29.5%
    Votes: 19 12.2%
    Votes: 37 23.7%
    Votes: 4 2.6%
    Votes: 21 13.5%
    Votes: 18 11.5%
    Votes: 17 10.9%
    Votes: 7 4.5%
    Votes: 3 1.9%
    Votes: 4 2.6%
