G
G1zm0
my bathroom floor is partical floor board, a little swelt but not much. i have got 6mm ply to recover it .
am i best using nails or screws? also should i ise urathain sealer before i use adhesive?
when cutting around water pipes and radiator pipes , should i remove the radiator then cut hole or should i keep radiator in place and cut hole and then cut from edge of tile to hole, fit and refit the bit i cut out?
also im thinking about replacing skirting with cut parts of ceramic tile, should i lay the tiles 1st or do the skirting 1st (cut and measured 1st ofcourse) should i lay skirting ontop of tile or tile near skirting..
sorry for confusing questions, dont wanna mess job up 🙂 any advice appreciated
