Discuss Cutting On The Curve in the Australia Tiling Forum area at TilersForums.com.
I tend to use a grinder for curved cuts, much more control than using a wet cutter and nippers. Instead of using a profile gauge, get yourself some thick lining paper and make a template, it gives much more accurate results in my experience of using both methods.
As Bri says, template for me as well, by far the easiest. I just cut some paper to the size of a tile then it makes life even easier.
Nearest bit of Corex or the box the tile came in for me! :)
But its all experience I suppose
Don't make more of it than it is Andy.
Just make a template to follow and u'll be fine!
And try set floor out so that it makes going around the pan easy.
In a perfect world u wanna dissect the pan on both axis!
Again with the basin pedestal if u can't remove it!
Jiggle between the two where poss to give urself the best chance!
Then it'll be simple as! ;)
Good luck, and don't forget the pics!:)
Reply to Cutting On The Curve in the Australia Tiling Forum area at TilersForums.com
  • Sticky
Hi. I'm relatively new to tiling, and have begun offering it as a service alongside my existing...
6K
Q
    • Winner
    • Informative
So I was recently asked to fit some 3m x 1.5m 6mm thin porcelain in a new tile showroom. Mapei &...
8K
Qwerty
Q
Hi all, I'm not much of a forum poster, and am also new here to this one. Additionally, in...
7K
GoneGuy
Macclesfield
Business Name
AF Tiling
    Votes: 9 5.5%
    Votes: 17 10.3%
    Votes: 12 7.3%
    Votes: 46 27.9%
    Votes: 21 12.7%
    Votes: 39 23.6%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.3%
    Votes: 19 11.5%
    Votes: 17 10.3%
    Votes: 8 4.8%
    Votes: 5 3.0%
