Discuss Cutting out door frames to fit tile under in the DIY Tiling Forum area at TilersForums.com.
Just wondering what height to cut clear - Tile + How much for adhesive?
The tiles are 59cm x 59cm porcelain and 9-12mm thick. I have a 20mm trowel. I think that is 15mm height so applied at an angle presumably will be somewhere between 9 and 12mm (depending on angle)... is there an official way to work this out?
The house is not that old so door frames are an MDF style material and should be easy enough to cut away.
Same as above, typically I’ll put tile down and lay card from tile box and cut to that.
Depends on how tile wraps around door.
Sometimes you’ll need more clearance because of the angle you need to get tile in.
Put the first full tile in place so you can use it as a guide to measure your cut piece, then remove the full tile and fit the architrave piece first then full tile, making sure you do both at same time.
Otherwise if you fit all full pieces around doors and go back later with cuts, you can’t get them in.
Boggs
1,118
Uk
You could just take the architraves off.
If it’s a newer build chances are they are only braded on so carefully lever them off and fix back when tiled.
widler
1,328
England
But then you most probably have to redecorate, no chance you can take arcs off on most jobs
Reply to Cutting out door frames to fit tile under in the DIY Tiling Forum area at TilersForums.com
I'm looking for solid answer or opinion. We had some windows removed on an exterior wall and...
Hi, I'm new to the forum and fairly new to tiling, my only previous "proper" job was my recent...
WHOLE BATHROOM REFIT - ALL WALL FULL HEIGHT TILING AND TILED WINDOW LEDGES. ONE SMALL WINDOW &...
Hello All, First post in this forum so forgive me if this has already been posted before. From...
DIY Tiling Advice Forum
Trending DIY Tiling Forum Threads
Wetroom and Tanking Systems Popular
MIdlands
DIY Tiling Forum
    Votes: 5 5.0%
    Votes: 8 8.0%
    Votes: 6 6.0%
    Votes: 25 25.0%
    Votes: 14 14.0%
    Votes: 27 27.0%
    Votes: 3 3.0%
    Votes: 2 2.0%
    Votes: 19 19.0%
    Votes: 18 18.0%
    Votes: 10 10.0%
    Votes: 5 5.0%
    Votes: 3 3.0%
    Votes: 1 1.0%
