Discuss Cutting out holes for sockets in the British & UK Tiling Forum area at TilersForums.com.
bluevin123
:mad2:Hi all,
Had a nightmare day,been tiling a kitchen with 300x600 white tiles,only one row of tiles between worktop and cupboards. The nightmare was 13 holes to cut for single and double sockets to cut out,along the width of the tile I had to make 2 sometimes 3 cuts in the one tile.
I used an angle grinder then a file to sort it out,took 3 hours on the last tile as it kept breaking. Never again.I would have used the wet cutter and done a plunge cut,but the wheel is to big.
A jigsaw that cuts tile or something like that would have been ideal...do you know what I could/should of done.
Thanks.
Vinnie.
DHTiling
Hi Dave,thanks but if its quite a small cut to make, wont the wheel be to big.For instance if Im cutting a square I cant get in the corners as it dont go right through the tile.
Hope that makes sense.
Vinnie.:thumbsup::thumbsup:
no problem with sockets etc vinnie....just lower the tile over the wheel and let it cut from the back , slowly until it breaks the face and just manoeuvre the tile to suit the hole...
Any hole/square to cut , just take the lines to the outside edge of the tile with your pencil etc and use this line as a guide to show where to lower the tile at....easy once you have done it....take your time and no sudden moves and it won't break......:thumbsup:
Reply to Cutting out holes for sockets in the British & UK Tiling Forum area at TilersForums.com
TilersForums.com has been online since 2006 and we've had many designs, even three forum...
Hi I have been browsing these forums for a while and have picked up lot of useful advice. There...
    • Winner
    • Funny
This is how I got covered in Celotex dust in the image from Simons post. It wasn’t much fun...
5K
Waluigi
Hi guys, sorry for long post, just after a bit of advice regarding my first proper complaint...
2 3
14K
Hi everyone I've done several trades across construction, and the thing I struggle most with is...
12K
    Votes: 9 5.5%
    Votes: 15 9.1%
    Votes: 12 7.3%
    Votes: 49 29.7%
    Votes: 20 12.1%
    Votes: 38 23.0%
    Votes: 4 2.4%
    Votes: 21 12.7%
    Votes: 19 11.5%
    Votes: 17 10.3%
    Votes: 8 4.8%
    Votes: 3 1.8%
    Votes: 5 3.0%
