Discuss cutting porcelain tiles DIYer in the British & UK Tiling Forum area at TilersForums.com.
tiler-101
No hang on, the diamond on the disc is held in the soft metal at the outer rim can be anything up to 1cm deep on some discs. You should be able to see this rim and judge how much is left. it wears very slowly, if there is some left then try that first.
If it has a bath yes it is wet. As it has a trough I am thinking it was designed for your needs as long as your not cutting megga big tiles.
101
redrhinoman
:yes: I work in a Home Depot and sometimes a customer will come wanting to buy a wet saw or a replacement wheel. I usually ask them how do they know they need a new diamond wheel. Obviously they say its not cutting anymore. I ask them if they have tried to clean the wheel and they say what? My question to the forum is what type of stick or dressing device do you use? I know that we don't have anything in our store for this procedure.
Jim Carlin
They make a dressing stone for sharpening diamond blades. Rubi, Siri are a few. I have used a cement block to do the same thing. The trick is to reduce the volume of water over the blade so as to create a slurry mix and run the blade through the cement. It will remove some of the matrix holding the diamonds thus exposing new pieces. The blades are actually made for cutting different materials such as soft stone or hard porcelain. A porcelain blade is comprised of a soft matrix which will automaticaly wear and expose new diamonds. Softer materials have a harder matrix holding the diamonds in place. Another trick is to keep the edge flat. Once ot rounds over it has a tendency to wander and not follow the line. Hope this helped and didn't confuse the issue.
tiler-101
DHTiling
philipdayton
Thanks to all for the advice, I bought myself a new disk from screwfix for £20 and it went through the tiles like a knife through butter!
Apart from having my pants pulled down by Topps Tiles for the adhesive.....£51.49 for BAL Rapidset Flexible!
All went well though, I've got until Sunday to get the bathroom finished. Long nights ahead I think...
Reply to cutting porcelain tiles DIYer in the British & UK Tiling Forum area at TilersForums.com
Hi I've been tiling for a few years now, I don't really do large format tiles but I've turned...
Hi, Need to choose a grout for the above. For the black floor tiles 300x600 am thinking either...
    Votes: 9 5.4%
    Votes: 17 10.2%
    Votes: 12 7.2%
    Votes: 47 28.1%
    Votes: 21 12.6%
    Votes: 40 24.0%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.2%
    Votes: 19 11.4%
    Votes: 17 10.2%
    Votes: 8 4.8%
    Votes: 5 3.0%
