The chances are it's your technique in using the cutter. You may be using the wrong size wheel, or not scoring hard enough.
Then there is alwaus a technique to using the breaker. on the rubi's there is a sweet spot which you want to be breaking it, i usually find that a number of small taps with the breaker until with experience you know when it will break, then one quick hard tap and it should break clean.
or you can apply pressure to the breaker slowly increasing it, whilst holding one edge of your tile firmly with the other hand and flexing the tile slightly up and down and there will come a point when it will break.
or you can if your cutter is on the floor, bit difficult to explain this one, right knee on the ground to left side of cutter, left knee on tile corner, left hand on breaker. right hand on tile corner. apply pressure with breaker but initiate break with right hand.
If you cant get tile to break clean which i must admit is very very rare, it's just the way you are doing it, then you could cut each end on your wet cutterto the correct side of your score line, then put back on the rubi and should break fine.
I suspect you need a firmer score line, and a sharper action on your breaker.
p.s all the above are only things i have done when faced with a tile that wouldn't break, and is not a normal thing to be doing.
