Guest viewing is limited
Discuss Cutting sqaure 'holes' in porcelain in the UK Tiling Forum area at TilersForums.com.
H
hrpuffnstuff
hi all
well I'm a newbie on here, but have been tiling for a very long time now, but I dont tile every single day, only when its part of my job
(I'm a Kitchen/bathroom installer)
OK....My friend has brought 400mm x 400mm porcelain tiles and I have to cut 8 x double electric sockets in these tiles.
Some of these 'square holes' are very near to the edge of the tiles.
So my question is this...............
How can i cut a hole in a porcelain tile to take a double electric socket.
I have 8 of the 'square holes' to cut
Cheers in advance folks
Time's Ran Out
:welcome: I doubt that's your real name!
Well Mr puffnstuff have you got an electric diamond wheel wet tile cutter.
If so make your marks on the back of the tile - take off the guard - and place tile over wheel. Works nearly every time for me.
You can of course use a 100mm diamond blade angle grinder.
Have fun.
John.
H
hrpuffnstuff
Have fun.
John.
Hi John
Thanks for the reply, yes I have, and didnt think of doing it that way:oops:
BUT a question.....WHY MARK THE BACK OF THE TILE??
Why not the front and then I can see what I am doing
Is it because its a PORCELAIN TILE??
Coz maybe I can use an angle grinder with a diamond blade that way
Cheers again
DHTiling
Angle grinder with a turbo blade....is better if you have not done plunge cuts before....
Plunge cutting next to a tile edge can be fatal for tile if you get the tile skew wiff and it grabs on the wheel causing it to break away...
A controlled cut with a grinder through the face of the tile then turn over and finish from the back the last bits that the grinder wheel didn't get to..:thumbsup:
Lay the tile on a bench/platform and clamp it down this will leave both hands free to steady the grinder..
H
hrpuffnstuff
MANY thanks Dave and to ALL that have answered
I think I will use the ANGLE GRINDER method, with the diamond blade
again...cheers
Time's Ran Out
If you cut from the back on a wet wheel you can control the length of the cut for the size of the blade. A wet cut will be easier than an angle grinder however Daves method is the safest way.
Unfortunately with other mentioned ways it would be difficult to set up a whole kitchen and 8 sockets so that they all land perfectly on a half tile.:thumbsup:
Have fun.
John.
DHTiling
Very true john.. i do plunge cuts on my rubi wetsaw as it has a removable guard....easy to do and cuts in one go coz you are cutting from the back...but takes practise to hold the tile still so it doesn't jump....
But for newbs...face cutting with a grinder will be better imo...then trim from the back to complete hole...
obobsmith
hi all
Is there not a better way to set out the job so that you either have a fairly "meaty" bit of tile round the plunge cut or good cuts using two tiles so you dont have to plunge cut near an edge.
Time's Ran Out
It what comes first - the sockets or the tiles!
There is no way I would set up all the kitchen tiling just to accommodate the sockets.
You've got to many factors with so many different tile types even to think it can be done.
However - you can move the sockets if there is enough cable (not that I would - I'd get an electrician) to make the cuts more even.
After all how many times do we have to straighten sockets etc.:thumbsup:
John.
Reply to Cutting sqaure 'holes' in porcelain in the UK Tiling Forum area at TilersForums.com
There's a video on youtube of a guy templating for large format floor tiles, and I get the...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
