Discuss Cutting sqaure 'holes' in porcelain in the British & UK Tiling Forum area at TilersForums.com.
on most jobs i set up an old bucket and fill it with water for weight,then i use this for setting tiles on for grinding,works a treat and it doesn't matter if you cut into it,its plastic.
Blimey, some of you take risks using those small grinders.
Anyway, i have a bench wet saw that i use for virtually every precise cut. For sockets, i pencil the tile out first and cut the amount that my blade will allow along said drawn lines. My blase will just about go through the back of a 10mm tile before 'overcutting. After i have 'cut' my square (which is too small to fall out of the tile on it's own), i then wet cut across 45 degrees to the points of the square. By this time 6 cuts should have been done. You will then be able to tap the tile through the middle of the square, then tidy up inner edges manually.
I might sound a bit of a knob here, but i find that most precision cuts should always be done with water. Much kinder to the tile!
So would you mess about setting your saw up for 1 plunge cut..?
Reply to Cutting sqaure 'holes' in porcelain in the British & UK Tiling Forum area at TilersForums.com
